Stuck caliper brake pad pin
It’s a break not a brake
fair play sir! well done
Won’t the brake pad pin be too long?
Ha, a sort of success lol.
At least you’ll know what to do next time.
That it will, hence why this caliper will be cannibalized for parts.
That’s good I was worried you might cut the pin in half, take out a bit in the middle then glue it back together
Wouldn’t that be an “elegant” solution. That just sounds like the break pads would be held purely by hopes and dreams :sweat_smile:
Alright mate, got the same problem, stuck bolt on my rear brakes, Yamaha fz6 04, the guy who I bought it off has put a flathead bolt in and the screwy isn’t gripping the groove, I’ve tried using WD40 to try get it loosened.
any help :man_shrugging:t3:
Flathead bolt!? What the hell. Jeez.
I would probably cut another grove into it to make it Phillips screw, then apply heat and bang in a big screwdriver and use a lightweight impact driver on it. Failing that, use a bolt extractor, and then replace it with the OEM bolt.
I’ve had a few bikes using a flathead bolt there. Usually with a very short grub screw following it in the same hole.
