I do it all the time, as my bike is massive and my drive is small, as well as my housemates parking being poor. but, is it recommended?
obvious potential pitfalls are you drop it, but what are the chances of the side stand collapsing and the bike falling on your leg or, worse still, frame damage as the very high load point where the side stand is attached isn’t capable of being taken.
Always done it on every bike and every dealer i worked in done it too, the trick is though not to lift it so its fully supporting the whole weight on the sidestand - just put some pressure on the handlebar and it will spin round whilst still on the floor reducing the weight on the stand!
Errr depends on the bike really, weight and height make a difference as well as the stands angle to the ground - a fairly 'straight down ’ stand (a la Guzzi ) would be a lot easier
as would light weight and - I think- a taller bike ( which gives you more control I think)
I have heard of stands bending but I have never heard of a stand snapping. :ermm:
i ised to do it all the time as my garden was too small to turn around in.
now ive moved and the sv is alot heavier than my old bikes so i try not to find myself in that situation.
i remember a friend doing it a few years ago and it bent the mount point really badly.
i cant remember which bike it was tho…
Its two 7cm metal discs separated by ball bearings and held together by a central spigot type thingy - universal so it fits the foot of all bike stands.
You can now spin the heaviest bike with your little finger!
Sell i t for £19.99 ( have it made in Chjna for 99p )
Have done it with my virago a fair bit. No issues with it.
I have problems spinning my beamer though. It’s fragile and goes all bendy. I’ve found that if you have a soft bit of ply under it in your garage , less stress on the stand and spins easier
I do it all the time with my CBR, the stand seems to be pretty solid, be careful when you pull it towards you as if you are too enthusiastic the bike can suddenly feel very light as it tips towards you. Honda stands seem fairly solid. Some Yamahas look as if they’ve spray painted a cocktail stick black and attached it to the bike such is the amount of flex under the weight of the bike.
