Oxford HotGrips fitting advice?
Anyone ever fitted Oxford HotGrips?
I eventually got the bar ends off, but how do you get the old rubber hand grips off? They are glued on I reckon. Do I rip them off with my bare hands and shour Gggrrrrrr as I’m doing it? Any tips?
Thanks
Hey fella,
Get a screwdriver (flat head), and prise the grip off the tube, and squirt some WD40 in the gap you’ve created, then twist the screwdriver around the tube to detatch the grip from the tube. You can also prise the grip from the tube, at the end near your switch gear and again, squirt WD40 in there and use the screwdriver to detatch the grip.
When that’s done, there should be enough WD40 on the tube for you to just grab the grip, and pull/twist it off.
Putting the new grip on is nearly the same deal, squirt WD40 over the tube, and on the inside of the new grip (lots of it), then slide it on. The WD40 will evaporate and the grip will be stuck in place. I’ve done this dozens of times with race grips, though your heated grips will probably be a lot bulkier, and perhaps harder to get on the tube. With the race grips, I use a tea-towl when sliding the new grip on, otherwise you can blister your hands.
Enjoy!
Thanks Jay. Not sure how long this will take. The kit comes with glue. Depending on how easy it looks to put the new grips on, I might use the glue, although if I b*gger it up I will be riding my bike tomorrow with metal bar ends LOL
Cheers
Well boys and girls, I got the old grips off easily, using Jay’s handy tip with screwdriver and WD40 (which I managed to spray on my neighbours cat, accidentally I should add).
Once I dry fitted the grips, I noticed the throttle side was too long and meant when I put the grip bar end back on, it locked the throttle i.e. it stopped it automatically rolling off when you let go. This would have been dodgy. I hacksawed off a couple of millimetres (doesn’t look modified at all). Then, in my cold garage, once my torch died I went to the off license to buy some candles. I then decided to perform the surgery (the wiring stuff) outside the supermarket as there is a big light out there.
Eventually got everything ready and noticed when I put my steering lock on, due to the position of the hotgrip switch, it would switch itself on every time I locked the steering. Bad.
Aborted wiring till the weekend when I amn’t rushed and it won’t be so bleeding cold in the afternoon hopefully.
Cheers again everyone who added comments.
No biggie, I got em at the Brum NEC show last month for 35 squids, and served by a mega biker babe.
when you wire them up you could be flash and ignore the instructions to save yourself the indignaty of having a flat battery from leaving them turned on/ having someone turn them on when you leave the bike
get a standard 4 pin relay, such as fog light relay from halfords etc
black wire from grips negative battery terminal
red wire from grips pin 87 on relay
pin 85 on relay to battery negative
wire from battery posative with fuse (that came with grips) to pin 30
find a wire on bike that is only on (posative) with the ignition switched on,(easiest to find normally wiring on top of starter solenoid/ignition relay) splice into this “ignition feed” so that it is still joined together with your new wire attached, fit a fuse low rating (5 amps best) into new wire and attach to pin 86 on relay
the pin numbers are printed on the casing of the relay at the base of the pins
now the grips will only work with the ignition on so they cant drain battery when you are away from bike, this is much better than wiring straight into ignition wiring as the grips will draw a large current if attached directly which can affect other electronics, using the relay still takes the main current direct from battery but could save embarrasment
Thanks mate, sounds like a job for an electrician
I either park in my garage or at the secure place at work so hopefully no potential g1t will walk past and switch the thing on. Will cover the controller box with a cloth or something.
If all else fails I could always trade in my FZ6 for a GS1200S that has hotgrips fitted for you :0 Nice.
Quote - OutofTowner’s reply there :
sts gs gglngeg m g gmng gs g sg g kg skljtg sjng s;rg serg s
rsejlgsne rgs le
rtw45yt4wy5thxfthgdtyg
swtwttwt54w6wt5w45ter54ey4e5
egerlg[l=4-l5t4w,5w5mserklgseyerth
rgsergdt
segsehdrth6t4e5rdrdth
rg serg645sergsegthgre6tysegsemg slekrglserg slekrg lg se
54e6y45dtrhj
serg653253453w
srg 4e
serghw4tse5y5ty45sergsemgsemg lopm][pkg-540kt
wtslr, twy43w5ye5yerthsy44w5w5y4w5yrer d
0-rgw455y4w55 5y 4w5y4w5y5
4w5tlwy4e4w54w
4e65y 45y 4w5y4w5 4w5y4w5ysrey5
I’d be down to a sparky too mate. No shame in it!!
Glad you got past the grip installation stage, GreatScott Sometimes modifying your bike is never straight-forward! I’ve come across this situation quite a few times lately with my rebuilding efforts.
ok…stop being so bloody funny!
GreatScott, it’s not as difficult as it sounds. I done mine last week same way as Outoftowner describes (but went one step further and wired em so they can only work when the engine is actually running, not just ignition on).
Little diagram below should help you.
OR, you could always just connect the 2 wires from the hotgrips direct to your battery (but this will mean that the grips can be switched on when the key is not in the ignition, which could be a problem if you forget to switch them off, or if little scroats come along and switch them on for a laugh to flatten your battery).
OR, as you said, if you dont mind paying, get an auto-electrian to wire them in.
tonup… good diagram, you didn’t used to work for ERF trucks by any chance? looks just like one of their factory wiring diagrams
That diagrams straight out of the Ducati handbook mate
You’re not going to believe this, I burned me bl00dy glove since the integrated wire heat element thing has reared its ugly head and is sticking out of the rubber on the left grip. Unbelievable, after all that hastle.
I am gonna take them off and put on those Oxford mitts instead. Not sure what I can do with the faulty good though, since I bought them from the NEC bike show and not from a shop. Would Oxford refund me if I sent the kit back to them and explained that the metal stuck out and burnt my gloves?
Total nightmare.
The couriers manage with Oxford Mitts. That is the only way you get cold hands on the bike - the wind against your knuckles. Mitts should fix it. I don’t want to get an electrician and some scroat probably would sabotage it, or this scrote may accidentally leave the heat on.
What should I do with the faulty goods?
Thanks again
Just got a letter thought from Oxford saying that I have to urgently change my grips as they have a fault. Rang them up and asked if it could wait a while and I was told NO.
Probably explains why they get hotter the faster I ride
Buggers, are they going to change them for you?
Yer, but just spoken to BabyJ and he reckons that it’s not worth it unless I catch fire Happy days.
That was after he eyed up my cigar.
This is possibly the best piece of advise I have had for fitting these grips. I have managed to flatten my battery twice
Also wired my autocom unit into the same circuit.
Just wanted to say thanks.
God I just passed out when I read those wiring instructions!
