There was me staring at it thinking I was being stupid but didn’t want to look down the page in case of spoilers. I thought it was 10-2 then /4
I took long enough to work that out though, I have a bit of a mental maths problem. Could do the most complicated algebra or anything like that at school… just couldn’t do it in my head
The rule about which takes priority is that unless there are brackets telling you otherwise, you ALWAYS do multiplication and division before addition and subtraction.
So for the question you asked, you should do the “2/4” bit first, and then do the “10 -” bit.
If it has brackets in though, you do the bits in brackets first, whatever’s in the brackets. So “(10-2) / 4” means you do 10 take away 2 first, (that’s 8) then divide by 2.
Apologies for being picky, but division is exactly the same thing as multiplication, the only difference is what you multiply by. A number divided by 5 is exactly the same as that number multiplied by one fifth.
Same thing goes for addition and subtraction: 5 minus 3 is exactly the same as 5 plus -3.
(Can someone PLEASE help me off with this bleedin’ anorak!)
Very true, it does indeed make for easier notation, but 558’s list implied that division takes precedence over multiplication, when in fact it doesn’t.
this may put me in the geek bracket (so what’s new) but the way it was written was a tad confusing… I read it as 10-2 / 4, so 2, but 10 - 2/4’s or 1 half, is 9.5 so fair play, I got it wrong, but only by over thinking it…
