Bought my son a 2013 Lexmoto LSM 50 and have been 'do’ing it up over the past few weeks.
The kick start works fine and the bike does everything it should … However, the electric start has a fault.
Hitting the electric start turns everything over but not engine ‘take off’
Solenoid checks out okay
Starter motor is kicking in, moving into position and turns the engine over.
Battery voltage okay.
Have tried elec start while coupled up to the car with jump leads. Still nothing.
I’ve tried pulling in the rear brake while hitting the start switch - nothing.
I’ve tried clutch in while hitting the start switch - nothing.
I’ve tried both the above together - nothing
There is a push button by the rear brake for which I have no idea what it is. Wiring diagram shows nothing so may be a rider add on. The switch is faulty but with ignition on there is 6v. I’ve tried connecting the two together while doing all the above again - nothing.
Anyone got any ideas of where I can go next … and I don’t mean the scrap yard Wise !!!
I’d check its sparking, I’d also spray a bit of easy start direct into the carbs if it is sparking and see if this works if it has a fuel pump.
I’m not sure what it could be without seeing it but they would be my first bits to check.
Failing that maybe the starter motor is not turning fast enough…
