Anyone used this as opposed to the ubiquitous ACF-50? My 19 Duke will be facing its winter soon and I want to look after her!
I found this exhaustive test and XCP came out on top.
had all year biker apply it last year …
my only concern is that as its tacky dirt does stick and trying to ’ clean’ without removing the product especially in nooks and crannies
I give The 250 a goodly spray down with maintenance spray,. It’s like WD40 except £2 gets you 600ml can when it’s on offer at Euro Car Parts. That and a wipe down with an oily rag keeps whatever the English winter and the DofT throw down.
Never saw any signs of corrosion on the Bonne’s either and look at the use and abuse they got white water rafting!
FS365 is not really like ACF50. It’s something that you would use regularly after rising. It helps neutralise road salt.
Should be used in conjunction with ACF50.
That’ll do although my preferred weapon of choice is this one https://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/penetrating-fluids/?542770980&0&cc5_857
Sorry got my prices mixed up it was the Triple QX brake and clutch cleaner that comes out at £2 the Triple QX maintenance spray is £3.50
