Had a little leak today! Would leg waxing help?
Try Tenna for Men… Tristan Palmer swears by them:D
Anyone who rides a GSXR would need them!
Tenna is all good for the small trickle, but a good wax helps speed run off…
Thanks for the advice, what wax do you find works best?
Well SexWax is a safe choice…available from most Surf boutiques!
Tried Briwax, but the fine steel wool caused chaffing and then I fell over.
why do you need it if you ride a gsxr?
Hell, if you don`t know now you never will, unless Chunky Monkey is willing to elucidate!
For situations like this you have a choice.
You can coat your legs in Febseal. If you do this any liquid will bead up and run off. Downside is it will end in your boots, so drill a drain hole.
You can buy what, in America, is known as a “motormans relief”.
Problem solved! Looks like I failed to replace my bilge plug, easy mistake to make.
Ah. So you already own a motormans relief.
That might explain a lot.
Any diver will tell you it is just your own central-heating…
Not in a Drysuit:crazy:
