You’ll probably need a friend to hold the device though as it has to be done one meter from exhaust, away from the bike to the rear.
I’m not sure what the required RPM you need to hold for the test is though. It varies according to engine configuration. Maybe someone else can answer.
Hmm, will that be accurate enough? I have a portable sound meter I use to measure phone speakers, this clocked me at around 115db, but I’m hoping it just isn’t that accurate at that high a level. I wouldn’t imagine my phone would be better?
Jay
I don't know how I clicked the link and missed all the text. I thought when I've had my bike done at track days they hold the mic right up to the exhaust?
I’ve never seen that. It’s always been a meter away. They should have a meter-long rod attached to the meter to set the right distance. Also the rev’s you do it at are critical. Your bike will make more noise the higher it rev’s.
My RSV4 was 117db without baffle and 104.9 with it in. Talk about close.
As I understand it, the measurement of the loudness of sound, is not proportional. An increase of 10 dB is double. So to double the volume of 80 dB, you’d then be at 90 dB. To double 90 dB, you’d be hearing 100 dB.
I've never seen that. It's always been a meter away. They should have a meter-long rod attached to the meter to set the right distance. Also the rev's you do it at are critical. Your bike will make more noise the higher it rev's.
Jay
Ahh, I get it then. They put the stick to the tip of your exhaust, the mic is at the top of it, 1 meter away. That makes sense.
Right, I’ve done some delving and found more info on how it works. It’s only 50cm away for cars. With twin exhausts it goes in the middle. This gave me a level of 103.5 and actually the static limit is 105db, so hopefully all good!
No :( I think I should be okay now though. The 103.5 was around 5,500rpm, people seem to think they will ask 5,000rpm and I’ll actually give around 4,750rpm ;-)
