Tank Paint Protection
I’ve noticed that the laquer on the sides of my tank is looking a bit crap where my legs are rubbing against it all the time - is there anything I can buy to cover it up - transparent preferably. It polishes out ok but the more I rub & polish it the quicker it’ll be down to the paint!
Cheers
They make floor tiles in an array of different colors, these stick to the tank, and can be trimmed to any desired dimension. How handy are you?
Yes, there are indeed clear/colored things to slap on your tank, to hide the things ya done to your paint. http://www.busters-accessories.co.uk/products.asp?id=24
These stick to the tank and if necessary can be trimmed. The one designed to do the job are more expensive than peel-and-stick vinyl flooring, so if you want to save a buck…
Vinyl flooring stuck to yer tank!!! you sure?
get some stomp grips or some tech-spec ones. more grip, can be peeled off later should you want to go back to stock
Ive got the clear plastic ones stuck to the side of my tank but they dont look that great.
If i knew how to take them off i would and replace them with the stomp grip. http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=STG55-10001
