Ive tried getting toonys sv started again today and no joy.
There is fuel getting to the carb but no spark at the plug.
Ive checked all the fuses and all seems to be fine, im quite confident when it comes to the mechanical side of things but electrics im crap with. Dont really want to go out and buy a stator and rectifier if its not that. Is anyone close to avely that is any good at testing electrical stuff on bikes and doesnt mind spending an hour or so trying to get to the bottom of things with us??
Something inback of my mind is saying dodgy clutch switch…swear was on a ride out and someones sv just cut out and wouldnt start but after a bit of jigger and pokery we realised it would fire ifclutch was pulled in but as soon as released it would cut out …but my memory is hazy
Regards the clutch switch.
The bike still turns over on the starter button with the clutch pulled in but with it out it doesn’t turn over, so I thought thst meant the switch was ok. Would it still do this with a faulty switch? and can you bypass it to see if that’s the case?
No alarm, I’ve not got testing equipment but neither plugs are getting a spark so just presumed it would be too coincidental for both to go at the same time.
Saturday is fine, cheers. text or call me when your in Hornchurch and i’ll come meet you. That would be brilliant if i could borrow the manual too as that will help massively!
