Stud detector for partition walls
Chippies, DIY-ers, handypersons… who has used a stud detector/sensor thing to locate studs in the plasterboard? I’ve read reviews for a couple of products and they say the cheap ones are crap, and so are the more expensive ones. Is it a complete waste of money?
I paid about 40 quid for one from B&Q and it seems to work pretty well. It allegedly does studs, pipes and electrical cables, and it’s been spot on every time for me so far.
I find that hammer drills find studs and pipes better than any detector money can buy.
I had to find an electric light cable that was live but plastered over, borrowed my mates detector and it worked perfectly. I would recommend investing in one as drilling into pipes is no joke never mind electric cables. Look for reviews of what is the best and then buy used on ebay :smiley: I got my dewalt hammer drill for £25 and a dewalt cordless drill in its case well used but excellent working order for a score.
yep i have one handy for not drilling into the water pipes etc in the walls:P diy must have:D
the cheap ones can be a bit naff but any mid range one will work fine. worth getting a multi one that will detect cables, pipes, studs etc
Invaluable bit of kit for any DIY. The only fault i found with my one was THE MISSUS!!!
She didn’t read the screen properly & drilled about 6 holes into the living room wall completely missing the joists, only to discover it came straight out the other side in the bedroom & muggins here was the 1 who had to sort it out :doze:
Drilling into pipes is good very good give me a call when you have :smiley:
I believe LIDL will be selling one from tomorrow. Sounds quite good.
http://www.lidl.co.uk/uk/home.nsf/pages/c.o.20090326.p.Multi_Detector_or_Ultrasonic_Distance_Meter.ar1
+1:)
Most women do not need an electronic device to detect a stud in my experience, luck that you were on hand to set her straight.:wink:
Technology simple, they work very well.
Stud detectors are often used at my place and the women have a 100% success rate (let’s not talk about the blokes though…).
Ian
Had one with a moisture probe, proved invaluable after positive stud detection.:smiley:
Jetstream Surely if you’ve found the stud, the damp bits will follow, so the moisture detector is a bit of a waste of time?
Back to the original post. Don’t buy the Screwfix one. It’s “a bit vague”.
Over to you Jetstream for a twist on “Screwfix”.
Ta all you advice-giving-bike-riding pearls of wisdom! I might have a look at the Lidl one - I’m going to get the money back from work in any case, as shelving is what I do mostly for my clients.
