The best I can describe this,it’s a electrical burning smell. The engine isn’t running hot. It seems to be running just fine. Wasn’t from the breaks because I was in M25 and didn’t brake at all.
Could you give an advice what can be.
Thanks for the opinions.
Regards
Have you got leaves or other litter trapped around the bike? I once had a Styrofoam burger box trapped between my exhaust and the radiator. Appalling smell and a real pain because I had just polished my pipes…
What bike is it?
Honda Deauville
Regulator/rectifier and wiring, check battery is charging
Have you had any problems starting it?
No,starts fine.
Could be because of the rain?
Started smelling on Thursday when was raining
Dirty Water evaporating on hot exhaust/radiator
+1
Regrec connector
Won’t expect rain run off to smell electrical.
Battery may be able to start bike even though it’s not charging. Get a multimeter on it to confirm regulator is okay before it cuts out on you in the middle of nowhere.
Dirty Water evaporating on hot exhaust/radiator TimRthis
I had a melted plastic bag on my headers a while ago. I thought I’d vomit from the smell until I realised what it was
My bike smells of burning, from front when it’s raining.
Bit alarming at first!
+1
