My front brake lever has become sticky, when i pull it in it stays in a little so the brake light stay on. The roads are filthy at the moment so I’m guessing it needs a really good wash, or is it more complex than that???
Hi, I’ve just had to strip and clean my front calipers as the brakes were dragging due to the amount of cr*p from the roads stuck in them.
Should be easy enough for you to whip the lever off and clean the pivot and switch to see if thats what the problem was.
