Split pin alternative?
I’ve been rebuilding my rear master cylinder, and it appears a split pin isn’t part of the rebuild kit I got. I don’t really have any halfords nearby, so what could I use temporarily/permanently as a split pin? :man_shrugging:
hair pin? wire?
Ive used a safety pin before, not going to pretend it was a temporary fix either
Wire coat hangar. Normal pliers will be tough enough to cut a bit off the end.
They used to be really useful for lots of things but don’t see so many now.
Cheers guys :+1: Hair pin repurposed… there seems to be a lot of them scattered around the house for some reason. Master cylinder assembled and fitted to the bike. Going to cross my fingers and bleed the system tomorrow morning.
Your going to ‘fix’ your brakes with a brittle hair pin? if that’s not a failure waiting to happen I don’t know what is.
eBayis your best friend for split pins
Oh, it’s just a temporary fix. The plan is to get a pack of pins to replace the hair pin and for any future work. I just wanted to finish with the bike so I can use it to get to work. I do loathe taking the public transport :unamused:
There seems to be loads of different options and sizes. Anything more specific I should aim for? Are there common automotive/bike pin sizes?
I keep one of these handy in the garage https://www.amazon.co.uk/Assortment-Stainless-Fasteners-Campers-Equipment/dp/B08GH51DVR/
The size of split pin will be determined by the diameter of the hole, measure the hole using a drill bit or take a punt on the 2mm x 25mm.
Danke.
