Uses a little flat style key. Haven’t been able to remove the remainder of key, tried needle nose pliers and a fret saw blade in there, but it’s too reluctant to come out. Also tried turning the key and opening the lock with the snapped off key in there, but no luck. Unfortunately, I don’t have a spare either…
Thinking I may have to go round to the school with an angle grinder and long extension lead. Any one got any other ideas?
Put a tiny amount of superglue on the part of the key you still have free. Try to attach it to the edge of the broken key. Wait. Then withdraw the broken part. Take key to shop to get another cut.
Chances of success are tiny but it’s all I can think of and what have you got to lose?
I had a similar situation with a snapped key in a Givi Pannier. I went to a shop near Notting Hill where a chap picked it open with a set of pins then removed the key and I was all set. He was highly skilled though. If you can’t move the bike then I think you should take an angle grinder to it.
Plot twist, have someone video it and set a timer running. If there are enough sparks you’ll make enough on YouTube to replace the lock.
