It’s got a Busa engine fella, what do you expect?! Other than that, you enjoying it? At least it doesn’t require tyre stops as often as you need pee stops…
It would eat chains but my chain looking after method is seriously anal and this seems to give me longer than would be expected out a chain and sprockets . Even when they are worn out they look like they were fitted yesterday they are kept so clean and fresh
MIght let u have a short bimble on it.
181.04 HP (132.1 kW)) @ 9500 RPM
146.00 Nm (14.9 kgf-m or 107.7 ft.lbs) @ 7200 RPM
More torque than most twins. 85ft torque from 2k revs too
Hence why the corded belt is almost showing through :w00t:
Must say though. Saw 172mph on the speedo (private roads) Scary! ands still wanted more
