Well went in there to get some tyres fitted to some loose wheels and get the newly fitted tyres balanced. I checked before i handed the tyres and wheels over that the could do the fit and balance and they said yes not a problem.
Returned to find that the rims had been damaged by heavy handed tyre removal and they don’t do balancing. I did ask and check they could balance them to which they said yes.
So avoid if you want you tyres swapped as the are a bit too heavy handed.
