Hi
Whilst polishing my bike today I noticed a couple of very very small rust spots on my tank. Now my Z750 is only 2 years old and so I am guessing that this shouldn’t happen !!! So is there anything I can do about it ? Would it be covered under warranty ?
Also, I had a Power Commander 3 fitted with a custom map. However, when I go over 85mph the F1 button flashes. Looking in the manual it shows that it is something to do with the injection system although when I turn the ignition on and off it stays off until the next time. Is there anything I need to do ?
Oh and one last thing…Maybe a silly question, but if the battery goes flat on the bike, would this reset the custom map on the power commander or be ok ?
Thanks
Chaz :w00t:
Wow, a bit of a marathon post;)
Firstly, you say rust spots. Would these be as a result of stone chips or is the paint flaking or bubbling?
Secondly, I’m guessing that Kawas are the same as Suzuki, whereby you can put the FI feature into “dealer mode” and get an error code on your dash. There will be a list of error numbers available somewhere on the net for your bike.
Lastly, a flat battery will not affect the mapping on your PCIII:)
Hey Chunkymonkey
Thanks for getting back to me. I dont think its bubbling. But should it be flaking after only 2 years ? Is there anything I can do about it ?
The F1 code is something to do with the injectors on the bike (according to the manual) but never came up before the pc3 was put on.
IM SOOOOOO CONFUSED
Don’t automatically think that the FI light means theres a problem with your Fuel Injection. The light covers a multitude of sensors on your bike from air pressure, throttle position and cam sensors as well as fuelling.
Find out how to put it in Dealer Mode and get the error code.
paint is flaking off the tank,? go back to the dealer and ask why…no way it should be doing that…
Wicked, cheers guys, I shall go back to Laguna’s and ask why !
Thanks
