So my boss is racing at Spa end of June and he’s invited me along. I’m going to head down a couple of days after not to interested in watching free practice etc!
Any advice on nice routes there? look on google maps I could run the border of france/belguim and go through the “parc naturel reginal de l’avesnois” but any advice appreciated or route you may have which I can upload to my prat nav.
Here are a few routes I have.
The first one is one a mate knocked up, it goes through Givet, which as me_groovy said is great 1st 80 miles are MWay, then its twisties.
I have attached some more routes I downloaded from ride mag, they all seem to do the 1st few miles on MWay, as far as I know its pretty boring close to the tunnel (perhaps someone else can disprove?) better to knock out a few mway miles, then it gets good.
After Lille you can leave the motorway and take the parallel road via Tournai to Mons, it’s a quiet road and much better than the motorway, then go to Givet via Philippeville and Beaumont. I’ve done this route many times and it’s very good. Beaumont is a good place for a break, there are usually a few bikes parked up and some good cafes. Givet is also a good place to stop. If you’re planning an overnight stay there is a good campsite in Tournai.
Thanks tiger, I’ll redo have a look at this. I think the route is starting to come together, defo adding givet to the journey. Will look at Beaumont as that stop off
ok so routes are pretty much planned now. So on to things I need to take, I’m not the worlds best Mechanic but do know my way around basic bits. Anyone recommend this or something similar?
Looks as good as any. Cable ties and duct tape are always handy and some disposable gloves. A can of get you home foam can get you out of a tight spot too.
As joby says, good starting point…I have one like that but added a few extra items.
You don’t want to be too heavy, but make sure you have socket / spanners that fit the common things like foot pegs, cables, leavers, fairings should they need tightening etc.
If you are going to check the bike over before you go, use the tool kit, make sure the tools actually fit. That little ratchet looks great but will it fit to tighten a leaver say
Take your holey socks, rancid underwear and worn out t-shirts, discard them as you go and hey presto you have plenty of room in your luggage for all those continental delicacies! (Does this sound like a Viz top tip?)
Bring spare keys. Spares of everything, bike, padlock, front door. Keep all the spare keys together but separate from the other keys, ideally in a pocket that you don’t usually use. And keep them on you at all times, just in case you drop your bike key down a drain whilst you’re out. Also good if you’re bike jacked, you can be seen to throw the keys away.
