Anyone got a idea how much bike shop would charge to remove a restrictor kit? , June the 20th next month when mine comes out can’t wait
Depends on the bike and type of restrictor - some have washers sat in the carb inlets, I think some have electronic restrictors - and I think some even have throttle stops !
Depends on the bike but I wouldn’t have thought it was a biggie…
Some have them in the cylinder head, IIRC.
I’ve heard that it’s approximately what it costs to fit them, which is handy if you paid for the restrictor kit to be fitted…
Go on line and start a search on the lines of “De restricting a…”.
I’d be surprised if you can’t find the “how to do it fix” within 30 minutes.
Some bikes are so simple you’ll fall about laughing. (Change the inlet gasket!) some later stuff requires the dealer to do an engine re map from his laptop.
If all else fails, ring around and get quotes. None should be an arm and a leg.
Had the restrictor taken out as part of the service, worked out to be about £50
