Me thinks I’m not getting the bugger off unless anyone has any experience of removing grips that have been glued on with epoxy?
Looks like I’m going to have to strip out the unit entirely and either replace with new heated grips or get some pretty grips in replacement. Tempted to go for the latter and get some heated glove liners!
heat them up if still working im guessing not. use a heat gun yet not to melt it then with a long flat head tap it between the bar and grip and keep doing this around the bar and itll crack free
shiver - I should be able to turn them on as I can turn on the ignition, just not the engine yet until I’ve changed the oil filter and replaced the alternator cover. No heat gun so will see what happens when I turn them on, thanks.
