A mate got his bike stolen this afternoon around 3p.m from Talbot Square. A bystander saw two scooters with scum on it towing the bike on Harrow road westward (starting from Royal Oak) with alarms blaring.
It’s a black Yamaha R6 (pics below). Number plate DV10 HKX.
seems they have worked out the flaw in even the best chain
Wise
Seems like they've worked out the flaw in the law - no one ever gets caught let alone punished! Thieves should have their hands removed with the same battery grinder they use.
Wise
Cypher
a battery grinder
Wise
I seem to remember seeing a kickstarter project for a grinder resistant bicycle lock - I think it worked in a similar way to chainsaw proof trousers with some kind of Kevlar fibres that tangled up the grinder wheel. I wonder if something similar could be incorporated into a decent motorbike chain - the easiest solution would be to make a sleeve out of the material but that's pretty easy to bypass by simply cutting outside the sleeved section so I guess it would have to be wound through the links somehow.
Either that or hollow chain links filled with napalm to give a nasty surprise when you get half way through…
a battery grinder
Wise
Either that or hollow chain links filled with napalm to give a nasty surprise when you get half way through.…
monkimark
Now that would be an idea. second it cuts through and sparks little localised bomb! The bike would take a hit as well, but I'd rather that than they get away with it.
What ever security that is designed a way around it will be found regardless .think back of impregnable security 20 years ago and how easy that is to bypass now ?
a battery grinder
Wise
monkimark
I would be interesting to see a grinder proof chain
I understand how chainsaw protection works but thinking about it a chainsaw blade is a sharp hook so the fibres are caught and blockup the chain & sprocket
an angle grinder works by friction & has a reltivaly smooth blade so how would the blade pick up the fibres & clog the spindle
Yeah I was a bit dubious - I think there’s a video somewhere, I’ll try and dig it out later.
The fibres would probably get snagged on the disc but I can’t see how they’d clog up the spindle unless there were loads of them, maybe they’re coated in something, or maybe it just doesn’t really work.
A grinder can be slowed /stopped by cutting a plastic /resin based product by the build up of the “grinds” clumping …BUT easy way round is to … remove the guards and face it anyone happy to be actively grinding a chain of a bike in broad daylight ain’t worried about health and safety
They should create some sort of chain or lock that explodes with some sort of ink on the thief’s face, with a colour that the police can quickly identify. Same thing they did with alarms and clothes.
They should create some sort of chain or lock that explodes with some sort of ink on the thief's face, with a colour that the police can quickly identify. Same thing they did with alarms and clothes.
WildBoy
I don't think any company would make that for fear of injuring someone by accident. Ink to the face could cause blindness...
WildBoy
Serrisan
WildBoy
Serrisan
even better
WildBoy
Even an unsuspecting mechanic changing your chain?
