Hi all. Any ideas on this one:
was riding home when out of the blue my 09 R6 went all sluggish on me and the orange engine warning light came on. Now bike runs terrible and getting Error code 35 on the dash (ignition coil open circuit issue I believe). I have bought one new ignition coil and checked each of the old ones, one at a time and still errors. I’ve also unplugged my PC, quick shifter connectors and un/re-plugged those connections. Still Error 35.
:laugh::laugh::laugh::laugh::laugh: Evilblade has given you the problem, now you need to figure out how to resolve it - i think Google will be your friend for this or one of the Yamaha/R6 forums as its probably happened to someone else.
Hi this might help -AH_1002Hi again,My previous post may have been a little off. I was thinking the R6 had the dual coils not on plug like it has. Though they are still set up in pairs so it’s not entirely different. I did some digging in the manual and found what could help. There are two coil circuits from the CDI - IG1 and IG2, each circuit powers two coils. So, the gray and black line runs to two coils and the other to the remaining two. Now what you have are two pairs of coils that fire together. Keep in mind the previous post - I-4, 4 cycle, 180 timing and 1243 firing order. One pair of coils must be attached to 1&4 and the other to 2&3. The problem is that in the wiring diagram they label the coils 1,2,3,4. This is confusing as it doesn’t refer to the cylinders. Since you made the wiring harness you should be able to figure out which coils are in pairs and then just make sure one pair is on 2,3 and the other on 1,4. If it won’t run swap the pairs. There’s no way to know for sure from the wiring diagram, but my guess is that IG1 = 1&4 and IG2 = 2,3.
As the error is…
35 - Open circuit detected in the primary lead of the cylinder #3 ignition coil.
The “pimary” circuit is the the first part of the ignition
circuit which used to be from battery via points to ignition coil.
And “open circuit” means there is a break in the circuit.
So it does not matter what you change with respect to HT leads
or spark plugs (that is the secondary circuit).
Go look for a lose connection or boken wire on the pimary
circuit for number three cylinder and as someone said if
you don’t know which one is number 3 then try running the
bike and check for the cold pipe, (it will be connected
to number 3 cylinder).
Ordered a whole loom from fleabay as couldn’t see any visible broken wires. So hopefully that will fix it. In the mean time I’ve changed the spark plugs, the 1st one was wet, other 3 dry. I thought the 3rd one would be wet?
