There the same, flebay is the cheapest if you dont mind second hand.
I got a new one for my Gixer of ebay for 180 quid…
They are easy to fit but you realy need to solder the wire that connects to the TPS (throttle position sencer) it comes with one of those little clips that cuts threw the outer plastic of the cable.
This is ok for a bit but can A. not make a good contact and B.Corrode if moisture gets in, again compromising contact.
Having said all that… I.M.H.O you also need to budget for having it set up by a pro on a dyno about 150 quid…
Ok the maps that come on the CD are… lets say “ok”
But a custom map is the only way to do it propper…
I started with the CD map but didnt rate it…
After set up at HM racing its totaly different.
It was running lean on the Cd map right threw the rev range and they got another 7 RWBHP aout of it.
Not from what I understand as this is variable anyway (this is the point of the unit). I think its the warranty issue that puts most people off getting it from the US. Although its cheaper you need to send it back to the US to get it fixed or replaced under warranty.
So Adz you know the bit where you said that you should solder the wire…Is this a Gixxer thing cos my PC has got like a multi plug connector that routes into the ECU.
I keep hearing of PC3s going up the spout making the bike cut out or idle incorrectly.
When I install mine on my R1, I’m going to A) Put it under the rider’s seat instead of pillion because there is the room and B) insulate all the connectors.
I don’t want to have the bike cut out miles from home because a faulty PC
HI AFROR1 GOOD LUCK TRYING TO GET IT UNDER YOUR SEAT MATE NO ROOM GOT TO MAKE SURE THAT NOTHING TOUCHES THE 3 LITTLE BUTTONS THIS WILL REALLY PISS YOU OFF IF IT HAPPENS SO SAVE YOUR SELF THE HASSELL AND PUT IT UNDER YOUR PILLION SEAT THIS WILL ALSO ALLOW THE SEAT TO STAY ON FOR THR DYNO GUY TO SIT ON AND YEAH SACFRICING THE STORAGE IF YOU CAN CALL IT THAT BUT BETTER SAFE STAYING AWAY FROM THOSE BUTTONS MATE
