Ok I know this is a bike forum but having kids I have a cage as well. This is the story and really need help.
I have a 97 escort (no comments please) it has a serious hunting/idle problem what happens is, when I switch the engine on it will idle at 3krpm for about 30 secs then hunt between 500rpm and 2krpm after this I will be able to drive in any gear like I have cruise control, me, my dad and a garage (owned by mates so not being screwed) have tried.
Replace air pipes
Idel controls valve
air pressure sensor
Anyone had this before or anyone have any ideas why the hell we cannot find the problem…
It could be an air leak between the carbs or injector body spary wd40 around any point where there is a gasket and the engine will struggle to idle at all and should spot once found.
If it is an injection model it could have a blocked injector that can also give you the same problem.
Might be worth cleaning the crank sensor pickup and wheel, but I guess they have probably already done that. Does it have a cam sensor too - I suspect not ?
Just general condition of the engine, if it’s sucking oil/water into a cylinder it would slow down, then ecu tries to bring it back up, long shot but it looks like you’re looking for something elusive.
