I’d stick the battery on an optimate over night and then for a long ride. Best thing is to get the bike service, engine flush, new oil/sparks/filters. If it has been standing for long, the oil is basically knackered. Old petrol in the carbs will also gunge them up, so they may need to be stripped and given a good clean, or you can spray a can of carb cleaner through the airbox (without filter) while the bike is running to get them cleaned out. Sometimes works. Good luck and enjoy the power (when it is running)!
Charged it and just went and tried and she started first time. Perhaps the battery standing for so long has made it less than perfect. Simple solution if it is only that.
Put some top petrol in to mix with the old rubbish, good excuse to go for lots of runs too.
Just bough some redex petrol treatment which will hopefully clean tjhe carbs a bit. I’ve used it in cars so presume it will work just as well in bikes.
Plugs are unlikely to be the causae but changing them wont hurt…battery low will reduce turn over speed but you really would notice that…
I suspect she is just a tired old girl and needs to be loved again…how many miles has she done…dont use thin oil use a good old fashioned thick oil, 20 50 for old engines…if you can get it not 10 40…if you had one I would check the compression but dont worry if you havent as it will only get you worrying…
Dont go trying to race it hard for a bit until you are sure she is tight and reliable…
I bought a '96 Bandit before the summer, had 32k miles on the clock, never been serviced.
First thing I did was give it to Dan at Central Bikes for filter & oil change, new plugs & battery. Starts beautifully, runs like a dream… they are simple machines but need just a little tlc… Enjoy Oh and sort the brakes out they are crap Qx
One of those silly little things that gets forgotten. The two central plugs are in recesses that don’t drain so the plugs have rubber grommet type things. Make sure that all the recesses are nice and clean and dry and the grommets are in place.
Bandits also seem to be particularly unhappy with batteries that are not perfect.
After that, it’s all been said.
Get/give it a decent service, then take it for a damned good hard ride. Then change the oil and filter again.
I’m going to change the oil after I’ve run her a bit.
When I took the old plugs out they were rusty so looks as though water got through the seals at sometime, I’ve made sure the rubber caps are now seated well. I’ll blow the area out with an airline periodically too to stop it from happening again.
The bosch battery I’ve put on should be a lot better than the non-descript thing I took off.
Still can’t make up my mind whether to put the redex petrol treatment in, someone said it may be a bit harsh for the o rings in the carbs. If she continues to start ok I might not bother now. I can always use it for the car at some point.
HiI dont no if anyone can help me, i have a 1998 bandit 600s i been having trouble starting it. It just wont fire i just brought new spark plugs, ive charged the battery, checked both the coils, cleaned all the connections. but still nothing
