Micro drill bits ?
Anyone know where i can get some today/tomorrow ? i need to drill out some main jets so looking for 1.2mm to 1.6 mm in 0.1mm increments or finer. None of the high street diy shops or hobbycraft do anything near that small.
I can get em on-line but not by tomorrow and its my last day off work so really want to get the bike running.
Have you tried the Dremel section in B&Q?I’m sure the one in Enfield does tiny size drills.
Failing that try Tilgear or Engleman & Buckham edit. Sorry I meant Buck & Hickman
I can pop into the B&Q old kent road on the way home and have a look if you want, then could collect them from me from work in the morning if you want?
Try Maplins - they stock drills from 0.5mm.
Thanks for your help guys, glad you realised the little error chunks , buck and hickman are getting in 3 each of 1.3,1.4,1.5,1.6 mm in the morning to there feltham branch which is about 15 mins away :):):slight_smile:
Tried maplins stock enquiry which has an impressive list of micro bits…which are all out of stock,will have a look when i next go past one tho.
