Hi Gang
I cant get the rear wheel spindle out of my 2003 R1. It seems stuck on the left (sprocket) side. What am I missing?
Ta,
Sneaky
Hi Gang
Ta,
Sneaky
I have been tapping it with a mmer. Just thought I better check that there aint summit that I’m missing before I start smashing the outa it.!
you must have taken the split pin out to undo the nut (if there was one)… perhaps caught on the chain tension block? i don’t remember what the back of an R1 looks like!
Split pin?
It has started moving now, but I think I mullered the nut!
no no no no no no wd40 will remove your precious dirt off your bike:D
Done! I used the MD method…a bigger mmer!
de-rust the spindle and grease it before it goes back in
Thank for the warning MD! Dont worry, theres plenty more where that came from!
Now where have I heard that before!:Whistling: Thanks for the tip!
Use Copper ease, having cleaned the spindle first and all bushes, spacers etc etc…
Ah, I have used LM grease now?
