2002 onwards Hayabusa flywheel , this is the bit you need to change on a 99-2001 engine to make it work with the 2002-2007 32bit ECU. £70 posted.
Set of Hayabusa throttle bodies , the TPS plug has been changed for a waterproof plug to connect to MBE/SBD loom. With 4 injectors which have done about 6000 miles £75 posted.
Hayabusa cam cover , black, few scratches but in good condition. £40 posted
Set of GSXR750 throttle bodies and injectors , have had the secondary throttle plates removed. £75 posted
Brembo master cylinder , used but in good condition, I bought it and never fitted it, ratio = 19x18 plus double banjo brake light pressure switch for road use. £80 posted
**Spare black Brembo brake lever ** for above, new, still in bag - £20 posted
Power Commander III USB for 2002-2007 Hayabusa , used but in good condition, £115 posted
1 set EBC clutch springs Hayabusa done 10 miles £25 posted
1 set clutch center and hub (the bits some people weld together) - used but very low mileage, I think about 100 miles - £30 posted.
1 pair short air trumpets Hayabusa MK1 - £15 posted
1 pair long air trumpets Hayabusa MK1 - £15 posted
1 pair front indicators , clear, unused, Hayabusa MK1 £45 posted
EGR replacement for BMW 2.0 TD engine E36 and early E46 - also fits MG ZT CDTi diesel and Land Rover TD4 - has additional take off for boost gauge and it’s made from powder coated steel not the thin flexible stuff on eBay which leaks after a few heat cycles, new, never used - £30 posted
4 x Pico fuel injector - same as http://atpowershop.co.uk/catalog/pico-fuel...power-p-99.html - 480 ml, have only done an hour on the dyno, replaced as they were too small - £180 posted
Kriega R35 ruck sack, used twice, perfect new condition, £75 posted
Pair of soft Oxford Roxter Panniers and Oxford Roxter soft tail pack , held on with bungee cords, very similar to this: http://www.mandp.co.uk/productInfo.aspx?catRef=901543 Used once for short trip. Panniers and tailpack for £40 posted.
ZX6R 2007-2008 PCIII USB, used and in good condition - £115 posted.
ZX6R 2007-2008 Yoshimura stainless end can , sounds great and removes the exhaust valve, £200 posted.
ZX6R 2007-2008 race/track fairings - complete set in white with tail piece, battery tray and front mudguard. £160 collect only.
ZX6R 2007-2008 HID headlight kit , ballast and bulb complete kit - £40 posted.
Starlane GPS track mapping and timing system . Brilliant bit of kit, tested but never used. Read about it here: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/37692 £280 posted.
