There are a few scratches on my tank they have not gone to the metal but have to the primer. Tried T-Cut but doesn’t help.
Any other suggestions, or anyone know of anyone that could take them out for a reasonable price?
If its gone through to primer - t-cut won’t do anything - you’d need to use that touch up paint and blend that using t-cut ; although I’ve never been able to get those to look at all good. I’d look into these spot scratch removing services - but i’ve never used one so I can’t recommend anyone.
PTX 40 Grit Sanding Paper is your answer
liberally rub all over your tank & everything will match perfectly
PTX 40 Grit Sanding Paper is your answer!!!!liberally rub all over your tank & everything will match perfectly
Wise
baglux and forget about it
PTX 40 Grit Sanding Paper is your answerYer it will bring back the lovely brushed metal look.liberally rub all over your tank & everything will match perfectly
Wise
LLoolLoLol
