ive had led indicators on my mark one fazer 600 for over a year, and took them off to put an undertray on. Wired them back in, but they are really, really dim, you can barely see them. I have the headlight mod done, and when i switch the headlights off, the indicators go really bright.
I have the resistors wired in parallel so they flash at correct speed, when wired in series they flash bright, but too fast
any suggestions?
I dont understand why switching the hadlights off should make any difference, as leds only require a tiny current so its not like the twin headlight mod is draining all the power
to be honest, im thinking of chucking them in favour of something with bulbs again
though, interestingly, ive just installed leds as the brake lights, and when the engine is idling they flicker, but when i rev the engine, they get brighter and dont flicker, like the indicators, could it be a prob with coil on the bike?
It sounds to me like you’ve got a dodgy earth wire that goes to your tail unit. It may be another wire, but as its affecting rear light and indicators, its most likely the earth. Its multi-meter time … give me a shout if you need a hand.
