Knock Knock Knocking on heavens door?
OK - let me paint the picture.
You’re riding along on your 2001 Honda CBR F4i, you’re up to operating temperature and you’ve been pootling on for about 10 miles.
You pull up at the lights and you suddenly become aware of a very very slight knocking sound - you pull the clutch in and it seems to go away! or at least not be so pronounced.
You do the same trip the following day and all is OK - doesn’t put a foot wrong. A week goes by and it happens again!
Basically, is it normal to have these hiccups? there seems to be no reason why it comes on and no reason as to why it disappears. I’ve since read up on others that have the same problem, but way way worse it seems and I’m wondering if I’m heading the same way? Are there any tests I can do EASILY!! to start eliminating possibilities?
To be honest, the noise is so slight and sporadic that I’m probably going to have to wait until it gets worse before its noticeable - or it might have gone away - Havent heard anything for ages now so it could have been just “one of those things”…i’ve always been a bit of a worrier!!!
How many miles has the bike done?? (when was the last service??)
46,000 miles - All services done via major dealer.
Last serviced approximately 1,000 miles ago - about 4months ago.
Dont know much else about the history of the bike as I only bought it a while ago - service stamps look genuine enough and guy i bought it off was genuine good guy.
could it be the cam chain tensioner? is the sound coming from the front right side? if so that’s probably it nothing major to worry about.
I must admit, thats the first thing I thought about - its well known that CBR’s arent too great with their cam chain tensioners.
I was wondering how they work though - do they take up the slack? and if so, do they do it like a handbrake does in that it gets to a certain point and then it clicks into the next cog along and tightens up? That would explain why I havent heard it in a while - self adjusting to a point.
Hang on, i seem to remember seeing something somewhere which showed you how to adjust them so i guess they cant do it by themselves.
Know anyone cheap that can tighten/replace it CHEAP!!!
if my memory serves me the cbr has an automatic tensioner so fixing it won’t be on the cards. I replaced it on my old 2000 cbr and it got rid of the noise but came back after 1000 or so miles if you want it replaced shouldn’t be much more than £100.
Odd that yours came back after just 1000 miles!
£100 I can deal with - who did you take it to?
F**K me I hope it is the tensioner, imagine how miffed i’ll be if I change it and the sound hasnt gone!!
Anyone out there with a workshop looking for some pocket money? Cant say i’ll be replacing it anytime soon but its worth taking names and numbers in readiness.
:slight_smile:
If the noise goes away when you pull the clutch in it’s not the tensioner, it’s just a rattle from the clutch.
Maybe your clutch basket after that many miles is slightly worn, causing the discs to rattle.
What I was thinking:cool:
Southern Cross up in Kilburn. There just around the corner from me literally and they do great work a very honest bunch.
OK - Brilliant - the rattle does go when i pull in the clutch - so how much we talking?
I thought something was up with the clutch when i popped it up on the centrestand to lube the chain - had it in idle and in neutral but the rear still turned slightly!!! Until I adsjusted the clutch lever that is.
You should hear the noise Yamahas make when the clutch plates rattle in the basket…
Usually happens from cold and goes away when the engine oil warms up…Nothing to worry about and most bikes make a clutch rattle noise.
It’s even a selling point on Ducatis with their school dinner lady style dry clutch ting a ling…Sounds like its falling apart and if it’s not a late model Duc…
It probably is :smiley:
I’m telling yah - next time we’re riding…you’ll probably hear it!
Whats the latest on the bike situ?
Me too, have had plenty of cars make the same noise in the past… :smiley:
Police still won’t let me see it :(Maybe their pimping it up for when I collect it :smiley:
OK so we can conclude this then? - what have we learned?
THAT I WORRY TOO MUCH!!!
Lets hope im not back in a month or two with a thread entitled:
“I FU***NG TOLD YOU SO!”
Over & Out.
But you said it’s knocking. Theres a difference between a knock and a rattle;)
Its definately a knocking :frowning:
Bugger - does that mean it is the cam chain tensioner after all? why does it disappear when i pull in the clutch? Presumably because i’ve taken the load off?
What are your thoughts on this?
As a rule cam chains rattle when the tensioners go, and so do clutches. I’d be inclined to get someone to have a listen to it before spending any money on it:cool:
Thats half the problem - its so sporadic that I never know when its going to do it. I’ll have to wait until its pretty much constant and then nip into the nearest garage. If i do this 3 or 4 times then i should start to get a consensus on what it is.
The saga continues!..
