I want to fit a flasher relay on my Kawasaki er6n 2014 bike but can’t find the indicator relay. Does anyone know where it is located?
Hi my name is George.
Thanks for your help @ National_Treasure.
I bought a pair of signals which are not flashing properly so I was advised to change the relay to one that will work with the new signals. Hope the one I ordered will work ![]()
If I was a gambling man I’d wager you’ve replaced the regular bulbs with LED bulbs and now the indicators are either not flashing or are flashing too fast.
Correct. I hope the new relay will solve the problem. If not, any ideas how I can fix this issue?
An LED turn signal relay should have you sorted
Had the same problem. Installed the new relay and now at least the front flashers are working as they should. The rear indicators however, dont work. Any suggestions what can be the cause of this problem?
