Are suportsports, superbikes and superstocks allowed to use traction control?(oem or after market)
depends on the class I think. certainly not for the superbike and senior races.
“Only a BSB spec Motec ECU or standard/kit ECU available from or listed by the manufacturer maybe used. The addition of a power commander type fuelling and ignition module only device type may be used with the standard or kit ECU. • No additional traction control type devices maybe added.”
all the rules are here: http://www.iomtt.com/~/media/Files/2016/Competitors/TT_Regulations_2016-230216.pdf
Yeah, That’s the only thing I have found while I was researching online. It says standard ECU is allowed. But isn’t TC incorporated to say s1000rr standard ECU? or is it separate device/control box.
Read Guy Martins lates book there was mention of the traction control and how he used it so I’m guessing it is aloud.
