Intermitent brake light
A few weeks ago noticed that my brake doesnt light up everytime i pull the brake lever.so i pull the brake level it goes on. second time on, third and onwards nothing. leave it a while turns on at the first pull…i suspect the connection. so gave it a clean with no change. called dobles and mechanic pointed to the rear brake. that it can get stuck and overright the front brake lever. gave it a clean and prob solved
until now. same thing happens no brake light… give rear brake a clean and now the rear brake turns the light but the front still doesnt do anything.
is there anything i can check? should i look for a new front brake switch?
thanks
Scorch solved this one for somebody last week
There be a micro switch on the front brake lever that needs cleaning, probably one on the rear brake pedal too :wink:
My money is on your front brake switch - I had the same problem last week - did you read my thread?
It’s a common thing on Hondas - happened to me on the Hornet and recently on my CBR.
When you cleaned the front brake switch did you clean the internal contacts? (you have to take it apart to do this).
I took my switch apart and the internal contacts (activated by a spring) were tarnished - I cleaned them up and everything was fine.
Watch the video below to see how to do it.
Alternatively if you haven’t got the time to piss about with the switch a new front switch is only £8.50 from David Silver Spares.
^ that’s the very post
Yep :smiley:
http://londonbikers.com/forums/1073776/brake-light-issue
Power to the people search function :wink:
Saturday Surgery is back this week. I have a couple of guys arriving at 11 ish, but if you could make it to Watford for mid afternoon I’ll sort it out for you. :wink:
hey dude i gave it a good squirt but dont think it help so was actually thinking of attacking that as well. !
been bit busy with the girls (a 3yo and 6mo) so not been following LB that closely!
thanks for the video will def check it out! now just to find the time to do it!
I didn’t realise there are now four of you at chez Panagiotis! Congratulations on the new addition to the family. :slight_smile:
Yes mate - the problem is likely to be inside the switch - there is a spring loaded contact that touches another contact when you pull the brake lever in - if these two contacts are tarnished you get the intermittent problem. The video is really helpful.
If you are busy and don’t have the time for the DIY a new switch isn’t that expensive.
so looked at the video and thought yeah i can do that in 15min! so went on and opened the switch up. as expected loads of moisture damage! went about taking it apart, and spend the next hour trying to put the fking switch back together!
didnt help that i dropped a piece and was looking for it for 5min! argg! anyway managed to clean it up put it back together and works perfectly again!
so big thanks mate! owe you a beer next time i see you! :slight_smile:
ps yep surrounded by girls at the moment! hence i need to spend more time in the garage
Excellent!
Yeah - it’s kind of fiddly and the parts are very delicate so you have to take care but the video is really helpful :slight_smile:
Hopefully will see you at the ace at some point in the future!
Hi Pan
Only just seen this post so this is just confirming what everyone else posted, but I had exactly the same issue on my CB1R - thanks to chris2332 for informing me :wink:
I got a cheap replacement from ebay which was crap and failed after a week, so got a real Honda part instead which has been fine since.
My bike is only three years old so was a bit surprised to be honest but there you go.
If it fails again I would replace it as it can be pretty dangerous with cars behind you…
thanks mate. tbh i wasnt that shocked as i do ride in all conditions but yeah will keep an eye on it! how much was the oem part btw?
You might want to sit down! It was about £20.
This is why I bought the ebay part originally…
This is the oem part:
http://www.partzilla.com/parts/detail/honda/HP-35340-MEL-003.html
I got it from this company online - a uk honda dealer:
http://www.lingshonda.com/
http://www.lingshondaparts.com/
The parts site isn’t working at the moment though, not sure if that is permanent.
I hope this thing doesn’t fail every three years :crazy:
David Silver does a pattern part for £10.20 (includes VAT).
https://www.davidsilverspares.co.uk/CBR600F1-2001/part_62561/
thanks guys
