They’re not legal and not really very effectual, but you’re unlikely to have any problems with them unless you’re already being pulled up for something else. You’ll need a friendly MoT tester, or to be willing to swap it back each year.
Whether they look good is subjective. Their effectiveness as indicators is not though. Following a bike using one of these you just see a blur of amber and red. The “indication” function of the indicator is severely compromised. If your bike has a hazard switch you’ve just removed that function rear facing at least.
I think Pan had one of these and it did look good even though a couple of times I wasn’t sure where it was pointing.
I agree with Silver, you can’t play by the rules everytime but be prepared. After riding on my KTM with a plate that was only a bit more angled (attached it to rear plastic on an SMC), I got pulled over and had to pay £100 for that… It was a very harsh cop in my eyes as the plate was perfectly leggible. I think he just had a bug up his arse that day because his wife hadn’t given him a blowjob.
I look at these sort of things with the mind of if you indicate and a driver hits you because they didn’t see it, the court may use the illegality of the lights as reason to rule you’re at fault.
I look at these sort of things with the mind of if you indicate and a driver hits you because they didn't see it, the court may use the illegality of the lights as reason to rule you're at fault.
me_groovy
Only if it can be proven on the balance of probability that the lights contributed to the cause of the crash.
In civil law, legality often has no bearing. It all comes down to what is reasonable.
