They don’t come in the pack anymore so was wondering where I can pick up some?
Halfords
Also which ones do I need?
Ta
Halfords
Ta
for led indies? are these for the hornet? if so all you need is a flash it relay (£19) i think yours is a 3 pin so you need the honda one (not the honda 4pin, that im selling
If you just want resistors then Maplins is your answer.
+1 These are great.
nope, its for susie’s 675
the rear indicators aren’t being changed yet, wont a flasher relay slow them down too much as a result?
No, they will flash at the same rate regardless of what load is put on them.
turns out (bad pun) that you can get R&G resisters for bugger all so went with that option
http://www.demonbikes.com/more/on/details/08960
they sent them out really fast, job finished today.
in case it helps anyone, the motrax indicators dont state a fitment for the triumph 675, but the yamaha ones fit (with a very small bit of adjustment) to get the wider thread through.
she now has flush indicators that flash correctly!
Hi all
If you haven’t already, fit them first, as alot of the LED lights have the resistors in them already now.
yep I fitted them first (to be honest i didn’t know when the resistors would come so better to have fast indicators than none).
the motrax ones also state that you need either a flasher relay or resistors.
cheers tho!
