As title, how to transfer gpx files to TomTom rider 400?
Until recently I was able to transfer gpx files to my TomTom Rider 440 by going online to
which now redirects to
ov2 (POI) files transfer OK but not gpx files
Whats happened here? Has TomTom broke it? Will they fix it?
I can’t find any information anywhere, not even of folk having the same problem, it can’t be just me!
Thanks G but I’ve been there, done that, no joy. It’s an AI bot that replies to every question with “I’m sorry, I don’t understand that question, please try again using different words”.
The troubleshooter is out of date and only refers to ‘My Drive Connect’ which is working because I can update the software and import ov2 (POI) files, I can no longer import gpx (route) files. The wizards have replaced ‘My Drive’ with ‘plan.tomtom’ and it doesn’t work but I can’t find a way of telling them. It’s as if Tomtom is no more.
Nope, I’ve already tried that and it doesn’t work. When TomTom Rider wakes up you can press an “Import Routes” iocn, select the tick boxes of the routes on the SD card that you want to import and press the “Import” icon, there’s a brief display of “Importing Routes” followed by “Import Error X None of your selected routes could be imported”
The previous website, mydrive.tomtom, re-wrote the gpx file before downloading it to the TomTom Rider and it all worked smoothly, the new website, plan.tomtom, doesn’t re-write the file into something that TomTom Rider can read, it goes through the motions but nothing is downloaded to the TomTom Rider.
Both download methods, copy from SD card and plan.tomtom, work ov2 (POI) files but not gpx (ROUTE) files. The TomTom wizards appear to have fixed something that wasn’t broken but it is now
Found a fix, tried 6 different gpx files and found the Tom Tom Rider can only read gpx TRACKS which means that it can read off the SD card:
Garmin Zumo GPX Basecamp.gpx
GPS eXchange 10. gpx
but not other gpx files such as the Garmin Nuvi GPX MapSource.gpx which I was using earlier.
A little odd having to import *.ov2 files via plan.tomtom and *.gpx via the SD card but there it is a work around for the Tom Tom wizards failing
