well have been given a pair or linear ohlins front springs.
Was wondering how I would find out what bike they fitted.
Thanks
Thanks
Get the tape measure out and measure the OD and spring free length first. Does it still have a visible marking telling you the spring rate as well?
Well the springs are 390mm long (ish) and circa 38mm wide.
The spring is marked, scratched on the bottom -80L.
The springs are linear not progressive.
Well that helps a bit. At that free length the’re definitely road springs - probably for conventional rather than upside down forks, at that diameter for a 43mm or maybe 44mm stanchion and the 80L probably stands for 0.8kg/mm Linear.Now the hunt is on to find bikes with that stanchion diameter.
Where can I find the info?
Cheers
