the drainage taps are closed? the four things sticking out the bottom, but there is two pipes that go to nothing but pish out fuel exactly like the drainage taps would when the engine is running
its starting to do my head in. i hope its somthing simple!!
take the float bowls off the bottom of the carbs and give them a good clean out, or if it’s been standing for a while the needles get a bit gunged up,where the petrol emulsifies, other than no idea!!!
It sounds to me like it’s the overflows from the float chambers.
If there’s a hole in the float, it’ll fill up with fuel and not float, which causes the fuel to run out of the overflow, but the bike will still run the same.
dont think it is a punctured float though, it doesnt have time to fill up with fuel! the bike is just being put back together so no fuel has gone through the carbs since theyve been cleaned!
i put them on connected everything up, turned on the ignition and pressed the starter button, turning, turning, turning fuel pishes out, turning, engine fires fuel still pishing out!
stripped em down completely, cleaned em out, then christof put them all back togther again!
connected it back together fired it up and hey presto not a drop of fuel from anywhere!! few bits of tweeking later today and she will be running sweetly!
cheers for the ideas/info on what to look for
in the end, think it was the pilot screws being slightly out! but cant say for sure as the whole lot got redone
well can be to sure cus i reset all the pilot screws, jets, main jets and cleaned everything out?? so it could be any of those, but the o ring bit is the bit that did it i think,
