anyone know where you can get some (around NW london)?
tried Llyods Motor Spares, they only go up to 1 foot spares (which isn’t big enough).
Halfords?
Trawl the net for local motor factors?
Can you use a gasket sealant or does it have to be paper?
thanks, ill try halfords tomorrow
and i could use sealent, but would rather paper (easier to replace next time i need to).
I always used to use blotting paper, and oil soak it after cutting out, because I could buy it in A3 size sheets.
Now that’s a useless bit of information because it’s probably harder to find A3 sheets of blotting paper than gasket paper.
Cartridge paper (oil soaked again) from your local stationery shop is a decent last resort and at least it’s available.
thanks, i may hope my clutch will last another week and order an actual gasket, probably the sensible thing to do…
Lots on E-bay 1M x 1M £14-99 or 500mm x 500mm £4-99
