Frozen Lock
Went to start the bike this morning, however the key wouldn’t turn. I could turn it the opposite way and get the parking light on, however couldn’t the ignition on.
This is the first winter I am riding, and just couldn’t work out what was going wrong…
Decided I would do the old car window trick and pour boiling hot water over the lock mechanism (incase is was frozen), which did the trick.
Just wondered whether this is a normal occurance on bikes…will I have to pour hot water every morning now until the weather picks up again? I leave home at the crack of dawn, so there is not much chance of it thawing out before I leave.
bit late now… but it is a bad idea to pour boiling water down the ingnition. apart from the obvious that you might crack something important but also you risk rust.
Id put some WD40 down it asap
oops…I didn’t pour it into the lock, just around it…is it normal for this to happen though?
Can of deicer will do the trick :wink:
do you use a bike cover?that should solve the problem
never happend to me but i do spray WD40 or ACF50 down the keylock everynow and then
i saw a suit pour hot water fresh out of the kettle onto his windscreen then saw the look of horror on his face as it shattered into a million pieces.
Do not ever do that rapid cooling or heating makes things go bang or crack like when my mum put a pyrex dish in cold water out of the oven same outcome.
wd40/gt85 and de-icer will do the trick
I have never had this problem even when when bike has been covered in snow for days.
As someone mentioned before a spray of WD40 should solve this.
Thanks for all the advice guys…feel really embarrassed now :blush:
Just went and checked the bike, all seems ok at the moment…you live and learn I guess.
Thanks again!
no worries :wink: next time check on LB first :D:P
I was thinking about it, but at 6am I didn’t think there would be many around to get me going straight away. Deffo “ask the experts” next time…
its just stuff to learn dude dont worry about it youll pick things up on the way and theres no harm in asking
Oh, and in the event that you ‘forget’ to do the wd40 thing and want to clear a frozen lock, the non-destructive way to do it is to heat the key gently in a flame (remember when most people carried a cigarette lighter?). Ideally you’re looking for nice and warm, most definitely not red hot and certainly no more than uncomfortable-to-hold - or you’ll start melting plastic bits and that, my friends, is wrong.
Press the key against the lock and apply gentle pressure. Reheat as necessary. Et voila!
You could of heated the key up and slowly inserted it.
WD40 isn’t kind to some plastics so spraying it around your display area isn’t a hot idea.
Spray WD 40 on the key and insert it…you don’t need much more than that…even liberally spraying it through the straw isn’t needed.
As the others said…hot water in a lock mechanism may work once or twice but what happens when it cools down on the ride to work and freezes in the mechanism again!!!
BM
Sounds like your lock may not have been frozen, seeing as you could turn it in the other direction.
Might have been in need of some lubrication anyway, and the cold weather made it a lot worse.
As said before, a little WD40 will do the trick, as burmonkey says on the key,
Or if you prefer to spray it in as i do, make up a piece of card and cut a hole the size of the ignition, and that will stop any overspray.
once treated it should be good for a few months maybe a lot longer, my previous bikes i did it once a year, and i’ve now Had my my Blackbird two and a half years and never had to do it, and it’s left out in all weathers 24/7
Thanks again for everyones advice.
