are there any other parts i would likley need after nearly running out of oil, how would i tell whats buggered?
i am ordering:
Fork Damper Retaining Bolt
Fork Dust Seals Pair
Fork Oil Seal Pair - Japanese Quality
Fork Oil Seal Retaining Clip (one is rusted to fcuk)
Yes you should have 4 its only a washer that makes the spring meet the spacer better… you can do without it its not critical but will change the length of the fork by a few mm
did you get the rounded bolt out? so long as you have the copper sealing washer you can match the bolt thread pitch and length with any bolt for a shop.
