I can get a subframe modded/cut/welded?
I’m planning a new fighter project and need a recomendation for a fabricator who is reliable and reasonably priced.
I used to use NWS but they have moved away from doing one-offs really.
Motorliner in Maidstone, but its best if you chop it down first and grind off the sharp bits, less work for them and it makes it a bit cheaper for you.
