I want to find out if it’s possible to Make a DIY version of what the new BMW has as standard. I was thinking maybe using an accelerometor or Gyroscope from a Model Airoplane as they calculate angles and stuff and have that connected to some kind of LED display mounted above my Dash, I know it’s probably very technical and probably well beyond my ability but just testing the water if it is something any of my Geeky Buddies can advise on.
Before i get all the obvious answers of “Why???” i will answer that now and ignore anyone that asks Why…
I love gadgets and Gizmos, a lean angle sensor seems like an actual good idea rather than a Gimic, i know the Manufacturers spec on what the lean angle is of my Tyres, i THINK i get very close to that spec, but in reality i know i’m probably a long way off, I also feel on some corners i could get the bike lower but don’t dare too in case i am close to the limit. I’m not after Pub bragging tools and will probably never share the info with anyone it’s just for my personal education and enjoyment, and i also beleive it will make me better at cornering as i will have an indication of how close to the limit i am and wether to be more careful or if i can give it some more lean
generally, you’d do best to use the sensors that are already in your phone and if necessary write an interface to that. Someone will have done it with an arduino, though from a quick google everything I’ve found is just an argument about the physics.
I don’t know how accurate an app would be unless you manage to get it mounted dead centre and flat. As they’ve fitted them to standard bikes I presume an aftermarket part will be somewhere out there.
@ Big Red S Thats brilliant, cheers. possibly exactly what i was looking for
@ MikeDerBike, I don’t have any chicken strips, i’m virtually on the edge of the tyre thats why i want to see how close my angle is to the manufacturers spec
I have a dozen protractors in the drawer of my desk for reasons unknown - you just need a bit of string and a ball of blu tack and you’re sorted
Might be a bit tricky to read mid corner though.
