Does any one else here have problem’s with there free view box keep flickering like mad?? like if a car goe’s past or some 1 walks past my room… it’s getting on my tits! and usually happens half way thought a program just as the good bits about to happen AHHHHHHHHHHH
Have you checked your wires? make sure they aren’t loose
yer there all fine… the other 3 in the house do it aswell arg!:crying:
i no how he feels:D:D;):P:w00t:
:hehe:
What about the aerial on the roof? My sky digi aerial had something knocking against it and it gave crap signal, got rid of the obstruction and it worked fine. I’m assuming you have a fixed aerial on the roof, and attached to your digi box? If all the boxes in the house do it and the signal comes through 1 aerial and it happens when a vehicle passes it might be your roof aerial, just a thought.
Do you have an aerial that is design for digital transmissions? A lot of older aerials cannot cope with the data density.
having trouble with mine at the minute as well, can’t figure out why though
mine the the crap aerial i need a better one…:w00t:
well it is '‘FREE’'view, its like tescos value stuff, what ya expect
lol
it to work would be nice with out having to do a mr bean with the aerial;)
If you Freeview doesn’t work when traffic passes or it rains that is usually because of your areal. If you invest in a better areal or get yours realligned then it’ll probably work fine. If you live high up in a building then see if you can borrow a friends portable areal and see how that works. I’m using a one for all loop in my room and that works fine.
If you are running 3 boxes from one areal then consider getting an amplifier for the signal. Everytime you split the cable you effectively half the signal strength so installing an amplifier will help there.
Finally it’s not the case for you becasue it is happening on all your boxes but a huge number of Freeview boxes were manufactured in a very shot space of time during the Freeview revolution and because they were manufactured on such a large scale a few slipped through with defects. If you have consistent problems with your freeviw box return it for another one.
yes i defo think it’s the aerial how ever mine is a magic box and turns it self over and off:hehe:
