I bought a new car (got it today :D:D) and I am going to sell my old car. Before I sell it I wanted to fix a small dent (so I might increase the asking price). Do you know any good place in London where they can fix it?
Is it worth fixing the dent? or should I sell as it is?
depends on size shape depth and placement of the dent.
if for instance its on a wing which is a single layer of rolled ally/steel, then its a fairly quick job to tap it out. if its small not too deep and on a faiirly flat surface then a high power sucker will work.
if however its on a double skinned part or body work, say for instance, a bonnet lid, then it makes it harder to get to in order to tap out. also if its on a curve or ridge it makes it more complex.
simple ones will be quick and easy with a suction cup
moderate ones will require a hammer and anvil set and some skill
hard ones require a drill a slide hammer and some filler.
as said above, car/age etc but wot i will say dont get it filled with filler etc, i reckon it will be better to be an honest car with dent than to fill it.
show us a pic! if it can be pulled out etc that might be better.
also will ya get on top of car wot you pay for it to be filled/pulled?
