I had return from holidays and the battery was flat and had to remove it and charge it.
Ever since I have done so the alarm seems to be very sensitive? and/or goes of randomly and doesnt stop. Even if I disarm and re-arm the alarm it will go off again after a few seconds.
Sometimes happens in the middle of the night !!!??
Does anyone have any idea if the removal of the battery is related or if it is a datatool problem?
All times there didnt seem to be anyone (or any animal) around ā¦but could be wrong⦠that doesnt explain the subsequent triggering tho.
Itās a quite common problem with Datatool
Try to google for nudge/movement sensor sensitivity settings, I havenāt found anything for S4, maybe you gonna have more luck.
Datatool advice is to reset sensitivity to lowest level. Probably you will have to contact their dealer.
Yeah it may do but⦠Have you got power? Does the alarm go off about 1 min after activation? If so then its the fuse could be the 10a, or the main fuse. I had this trouble with my bandit 600 and a data s3.
See hoe you get on with that, The alarm will play up if the battery charge is low as it monitors the ampage throughout the bike, Any drop in power is seen as a threat.
no it doesnt go off a few minutes after but rather hours later⦠?
the battery was just charged and optimised so dont think a low battery charge would be the culprit.
I have the exact same problem with mine on my S4 Red, its a right pain, iāll be laying in bed and then have to get up at 1 am or what ever to check some hooded thief isnāt in there, i solved it by going through the manual and setting the nudge sensor to the lowest setting. seems to have done the trick.
in which case check the fuses, one on the bike and the one in the rubber case. make sure the connections are not loose. other than that, im all out. get it down the dealership, use the old āused datatool for years and never had this, what you going to do about itā
arh cr@p, the devil lives in your electrics, see the datatool specialists, if they dont solve it, then you may want to seek out a priest for an exorcism
