so the factory spec on a GSXR 600 K1 is an 18.2lt tank capacity ,
well…
I’d say that was cutting it close wouldnt you? I literally ran out on the forcourt :D:D:D
Plus the wierd thing was I had exactly £16.55 in change in my pocket by chance??? Im buying a lottery ticket tonight
Unlikely, pumps as they are measuring devices in theory have to be calibrated. Most tanks are measured to a mark or a point and then the volume is measure from that, it doesn’t necessary mean that it won’t take more. My tank is to be filled to the lowest point on the collar, but there is probably room to squeeze a bit more in before it hits the overflow.
PGH, let me know what numbers you choose, I’ll share the winnings with you.
