Hi guys, I wanted to purchase a set of levers for my bike and noticed there are two size options, long and short, are the sizes due to hand size?
Thanks
Thanks
No, they’re due to tastes. A lot of people prefer the shorter ones as they’re less prone to snapping in the event of a spill. Long ones are perhaps slightly longer than stock? (from what I’ve seen, needs confirming).
Yeah I have the Long versions…still sexy but SO wish I had got the short ones, as I think they would suit better…next time ![]()
I believe shorties are better suited if you’re a 2 fingered operator!!![]()
CRGs are the same length as standard. both allow you to use two fingers, whereas normal levers dont on some bikes.
the long ones have have breakers in them so the end peice is the only bit that should come off (to the length of the stubbies). going back to 4 fingers on teh long lever might help with brake fade also. you can also get flip up attachments that allow the lever to move up if there is an impact if its a particular concern.
have yet to see a race bike run stubbies. its just for looks
hurt my hand boxing a weeks back, and i couldn’t work the clutch with two fingers, and had to click it back in to use my full hand. was f ucking glad i’d bought the full length ones.
